21 - 40 of 48 Posts
2019 Dodge Challenger Scat Pack Shaker
Subscribed. Anyone find a solution for '19 SPS?
You can cut the old tube to fit, OR check the other forums where someone posted a solution (can't link here)
Thanks. Google'd for "mopar pn 68322216AA" and got results. Any of our sponsors carry this air duct part?
I'm not home now so can't confirm the fitment based on the online pics. Hope it works tho...
that new part # 63822216AA...
does your stock CAI box have the square cut-out hole in the front (facing the radiator support)?
if so, that tube probably wouldn't work as the tube would insert into a round hole in the airbox.
Odds are the '18+ T/A (they had lighted inner headlight ports) used that setup. I noticed a local member's new '18 T/A has the tube feeding from the Air Catcher port into the T/A / Mopar CAI.
the T/A box is similar, but different to the Shaker CAI. Neck of the filter sits up top edge of airbox vs. the shaker version.
The yellow example is the T/A CAI, the red example is Shaker CAI. The Shaker airbox has the 3" x 3" square hole in the front used on '15 - '18 models)
It appears the T/A filter is vertical orientation (barb for PCV fresh air is below neck) and the Shaker version is horizontal (barb is to rear of neck). Both use the same filter element.
2019 headlite block off plate
I have a 1320 with same block off, I have to order extra small T9 or T8 torx bits to remove screws. Are you saying that the stock Hellcat tube and air box wont work on the 2019 Scat Pack?
19 scat pack triple nickel
Got the cap off. The intake tube will not fit so hopefully I can send back to Amazon. However, I do not really feel it’s needed, looking in the headlight you can clearly see the air cleaner so I feel most air will reach the air box anyway.
Also, there is a line labeled “A/C” that plugs into the back of the air filter. Does the SPS use cool air from the A/C to cool intake air?
What size was the torx screws to remove? Thanks
In other threads they are saying T9
21 - 40 of 48 Posts
