Just wanted to share something with the community. I have a 2020 R/T Scat pack and so far have installed two of the most common mods, oil catch can and Hellcat headlight to intake duct.
The oil catch can install was as described in endless forum discussions. However, the headlight to intake duct is considerably more difficult on the 2020. Apparently Dodge has decided it should not be so easy to add this mod.
Where on earlier cars all you had to do was remove the plug in the headlight, you now have to remove the light. Dodge added two T5 screws to the light with very little clearance to remove. Now you have to remove the light box from the light in order to be able to remove those two screws. It's relatively straight forward but just be prepared to spend more that 5 minutes doing the mod.
2019 Scat Pack triple nickel 6 speed manual.
Actually if you get the T5 bit and a 1/4 in socket (I think it’s a 1/4) you can remove the screw pretty easily without removing anything...that’s how I did my 2019 scat.
Welcome to Challengertalk Gunny ;) It's been fairly well documented how to remove the set screws
That is what your 2020 looks like, correct?
PS Thanks for your service ;)
Exactly what I did on my 2019, use a 1/4” ratchet and T5 socket and it came right out no need to remove anything else.
Thank you. Sorry about it being a repeat post, I had been all over several forums and never saw that specific post.
Yes, that's my Scat Pack. Ordered it from the factory in june, picked it up July 13th. According to Dodge they never built another 2020 like it.
