1 - 12 of 12 Posts
Can you tell what is leaking?
How much coolant has leaked out out?
As long as you didn’t continue driving it once it got hot, you are fine. It’s continued operation while in an overheated state that will kill a Hemi.
2021 JEEP Wrangler Unlimited Willys 4X4
Have you been involved in any really “spirited” driving?
The coolant reservoir seems to be a common issue (it is plastic and can leak at the seams) in regards to coolant leaks, although I’d deem it odd on a low mile, newer car such as yours.
Have you verified the radiator cooling fan motor is working?
Discussion Starter · #4 ·
Yes the fan motors are working I didn’t even check to see if the cap was loose I just immediately took it back to the dealership and got a loaner car
Discussion Starter · #5 ·
Also I am in Chicago and the weather isn’t that hot either it’s only 80 degrees today I notice the smell of coolant coming from the engine bay and I immediately pulled over and check the engine bay.coolant splashed everywhere over the engine bay
Could have been anything. Loss of coolant will make it overheat. Radiator, waterpump, hoses. Let the dealer fix it under the warranty. Strange that its that low mileage and an issue. Just keep an eye on it when you get it back to make sure the coolant stays full.
That you found coolant splashed in the engine bay is telling. It would have had to hit the spinning fan blades to get scattered everywhere, so the source of the coolant is likely a seem on the radiator (where plastic vertical tanks along sides are crimped to the horizontal metal fins) or a hole in the heat exchange section itself (from a rock hitting it at high speed, etc).
Either way, the cooling system would need to be up to operating temp and under pressure to actively spew coolant out, so it wouldn’t be noticeable until driven for a while.
But you said the dealership had it now, so hopefully they’ll diagnose it and fix it properly, and you’ll be back in business in no time.
Discussion Starter · #8 ·
There was a lot for coolant spill over the top and lower engine bay with smoke coming from the top of the engine bay as well I’ve had this same problem in my 2014 Dodge Challenger SRT.Only with 1800 miles is still not good for a new car
1 - 12 of 12 Posts
