2021 Challenger SXT RWD single piston calipers change to double or 4 piston
273 Views 4 Replies 3 Participants Last post by  staffy5150
What's up community, got couple questions regarding calipers. I have single piston calipers came with 18in. wheels front rotors are 13.6 in. / 345 mm and the rears are 12.6 / 320. Car has a square setup with 20 x 10.5 Rohanas on it now. My question is how much bigger do I need to go up in rotor size to change the calipers? More than likely go with 2 pistion calipers, and drilled rotors. Just asking if its doable without too much hassle.
The SXT single piston brake system (18" wheels) front rotors are only 12.6". If you got 20" wheels then you got the R/T brakes which were dual piston with 13.6" front rotors.
The rear rotors were both 12.6", solid with 18's and vented with 20's.
Reactions: 1
@Slidd put after market 20s on. It will accommodate larger rotors correct? I either want to put dual piston or four piston calipers on. I just want to know if it will be an issue. I've read in other threads RT calipers are interchangeable with the SXT without issues. I had to put spacers (7mm) on the 20s rubbed a little on arm.
The SXT Plus comes with 20" and it has the "R/T brakes". They will fit with 20" wheels
