I went to the build and price section a few weeks back and the 717HP Hellcat, as usual, had a 6 speed as an option. I go back yesterday and the 6 speed option is gone. I contacted Dodge via the chat and they couldn’t tell me anything. Is the 6 speed still available? I have ZERO interest in a Hellcat with an automatic. I’ll keep my 2800 mile 2015 Scat Pack Shaker.
I would hazard a guess the 6-speed is not available. That you found it offered then found it gone I think is a good (or bad) sign that is the case.
The word is or has been the 6-speed has been dropped from the Hellcat (and RE I guess) cars. Emissions maybe. But some other reason is possible or it could be a combination of reasons.
Regardless if you do manage to put in an order with the manual transmission option selected be sure you get a copy of the official order which clearly shows you were able to select the manual option.
Also be on the lookout for an alert/bulletin or change order from Dodge which states the manual option is not available and your car will be built with the automatic. In this case you probably will be given an option to decline but if you fail to then that will be taken as a sign you accepted the change.
But if you have an official copy of the completed order form with the manual transmission option seleected if the car comes in with an automatic you have the option to refuse the car as it was not optioned as you ordered.
