So I have had my 16 Challenger Scat for 3 1/2 years now and just rolled 20k miles. (Purchased new 8 miles) I also have at least 50 Drag Races under my belt. I have had rear end whine for most of the time I have had it. It has not bothered me because most of the Hot Rods I have owned in the past have had gear whine. So I would consider it normal. However, after reading about all the rear end changes Mopar has done....I decided to change the Diff Fluid to see if it would change anything.
I selected Max Gear Royal Purple 75W140 for a couple of reasons. I have used it in the past in manual gear boxes and the results have always been spectacular. MUCH smoother and shifting is 50% + easier and quieter. Pretty slick stuff by my personal experience. I decided to use 75W140 because I want the best gear protection...period. Factory's tend to use lighter fluids in everything to maximize gas mileage.
I have the Per4mance Diff Brace.....and I had to partially remove it because it blocks the fill hole. That blows.....but the brace is awesome and worth the wrench time.
Also....the Diff plugs are Allan heads.....not Torx . I see some people recommending a T50 bit but this is not correct. The T50 DOES fit snugly in the Diff Plug.....but the correct tool is a 5/16" Allan bit. Neither were very tight fortunately. Going back take care to not over tighten. The housing is Aluminum so go to "snug" and bump just a touch.
I purchased the bottle pump from Advance Auto for 10 bucks and it worked FLAWLESSLY! Well worth it. Also a tip from decades of wrenching: When the diff fluid is drained.....spray "brake clean" in the fill hole to flush out any remaining oil and particles. Then I use my air hose blower in the top fill hole to completely blow out any remaining fluid or particles. If you have compressed air this really cleans out the housing.
My RESULTS: My fluid looked fairly clean watching it drain from the Diff. But in the pan...it is dark. Taking the pan in the Sun.....and sloshing the fluid around.....there was zero metal particles and no smell of burn. It felt slick to the touch. At this point I was not expecting much of an improvement.
I went on a 15 mile drive with a mix of city and country driving with a stop for groceries. Speeds ranged from idle to 90 mph. Radio was OFF the entire time. The rear Diff noise was fairly loud before. The first few miles it did not change too much. But then it started to get much quieter. By the end of my drive ALL the noise is completely gone!
I have an aggressive Trans Tune and the shifts are fast and firm. Every shift you feel and hear a slight metallic "clunk" or "tink". Again...normal to me compared to past Hot Rods. Now...all the clunk and tink are gone. Also...you cannot "feel" the shift either. It now just shifts lightning fast.....silently. You can now tell there is a "cushion" in the gear set. Cruising the gear whine is gone. It was similar to exhaust drone. Different speeds produce different pitches. Now GONE.
This tells me the Factory fill is not the best fluid available for our heavy and powerful Hot Rods. This was time and money well spent....and once again the RP did it's magic on gears. It only takes about 1 1/2 quarts so it needs to count!
I would HIGHLY recommend changing your Diff fluid because of the aforementioned results. If you wait too long you may have to have yours replaced. Warranty or not.....I would rather protect what came from the Factory.
At the end of my test ride...I did a couple of mild launches and the 315's spin evenly and smoothly. The Anti Slip additive comes in the fluid and works perfectly.
And no...I have NOTHING to do with RP.....so please do not go down that road. Just my personal experience with the stuff. I only use RP for my gears. An easy job and well worth the effort
