I'm wanting to put a 315 tire in the rear on a 2015 scat pak. I wanna keep the same wheel look. Does someone make a 20x10.5 or 11 so I can get a 315 on?
Thanks
It is a grey area. Many factors to consider.
U want to be sure to not rub.
12. 5inch seems to be the magic number over that you rub. And all the tires are different. (Check on tirerack for the specs)
Then another key factor is how hard u cornering with it. (Roadcourse track? Just aesthetic?)
Is your car lowered?
Anyway,
https://factoryreproductions.com/shop/dodge/style-70/
After months of research, i found out factoryreproductions could be the right way to go. Cheap and seems legit.
10. 5 on the rear but I would personally be with 305 max.
They have the right offset.
I talked to them they said some of the people have installed a 3mm spacer to avoid any problem.
Fly
Sent from my LG-H872 using Tapatalk
