1 - 20 of 67 Posts
Sorry I don't have pics but that paint looks outstanding. Is that a ceramic coating?
Sent from my iPhone using Tapatalk Pro
I'm curious also. I'm looking at a rear wheel that is 20x10 +24mm offset. Want to run 305/315 without rubbing
St coilovers, 20x10.5 on 315/35/20 on rear, front is 20x9 on 275/35/20
The front isn't dropped all the way.
The clearance between the rear tire and wheel well looks close or little room for travel. Does it rub when you make sharp/fast turns? How is it when you hit a speed bump, etc.?
I have my fenders slightly rolled, they are rubbing so will roll my fenders more and it should be fine. If I would've went with a 20/30/315 tire I would've been fine. I really love the look so just going to keep the tire and roll the fender. I'm planning on bagging the car so it was something that needed to be done anyways.
if I don't lower my car (2015) will I still need to roll the fender to get 315s on it with a +25 offset 20X10.5 rim? I have SRT springs I may put on it. I do not want to roll the fenders. Thanks.
1 - 20 of 67 Posts
