Discussion Starter #2 (Edited)
NEW IN PACKAGE BALANCED and MATCHED ROTATING ASSEMBLY
SPECIALLY DESIGNED FOR FORCE INDUCTION ENGINES
FITS 2006 TO 2014 ALL 5.7L 345 CID HEMI ENGINES
NEW IN PACKAGE COMPLETE ROTATING ASSEMBLY, THE PERFECT WAY TO BUILD A FORGED STROKE ASSEMBLY FOR YOUR SUPERCHARGED OR TURBO CHALLENGER, CHARGER or CHRYLER 300.
KIT INCLUDES NEW BALANCE FORGED MOLNAR TECHNOLOGIES CRANK and H-BEAM RODS, CP PISTONS, RINGS (NAPIER) AND CLEVITE BEARINGS, MOPAR RELUCTOR RING KITS!!!!
- 4.050" STROKE FORGED EFI HEMI CRANK, W/2.000" ROD PINS
- MOPAR RELUCTOR RING-32 TOOTH FOR ALL2008 5.7L and 6.1L HEMI
- 6.125" DODGE EFI W/9.27" PIN, 2.125 JRL S/8- ARP2000 BOLTS
- CP PISTONS, 3.937" BORE DIAMETER, 428 GRAMS
- CLEVITE MAIN and ROD BEARINGS
$2799.00 + 99.00
for an additional $499.00 will include ARP main stud kit and cylinder head stud kit
in stock and ready to ship,
Luke
Is any work to the block required to handle that much stroke? I imagine new heads would be necessary?
What cam, exhaust, tuning, etc is needed with this?
What is the end hp/tq?
Is this what you are running in your R/T?
Thanks!
all questions where the answers depends on the desired end product, will require custom tuning, camshaft and cylinder heads can remain stock, porting on the heads would be recommended, this kit is designed for high boosted applications, 11/12 lbs of boost or better
as we go thru our install coming in today, we will post some specifics
any high boost engine must have very low restriction exhaust, catted mid pipes is an engine killer on a high boost vehicle, most engine builders will not warranty a high boost engine thats has catted mids
headers and offroad mids are highly recommended
Luke
