1 - 20 of 44 Posts
Couldn't resist the local dyno day, loaded the hot rod on the trailer and kept this baby shiny today.
I have never even seen a dyno run except in video's, so this was quite the experience as I actually went first. Had a great time.
Seems like the factory version is not too far off from the cars they did all the testing on the last few months.
This car is going to be a blast!!
Nice! Keep in mind (from what I've heard anyway) you should see a slight horsepower torque increase after around a couple thousand miles as the engine gets fully broken in and the parts loosen up. I'm guessing if you take it back say after 5000 miles you might see around 425 rwhp.
The Red Letter Dodge car clocked up tons of miles on the tour.
Either way you're looking at around 480hp if you use the standard 15% loss! :D
Glad to see some real dyno numbers. It does seem that the 392 is producing more than the advertised numbers. Any idea what driveline loss percent is?
Awesome numbers Goehner. Yeah, dyno days are fun. Had mine dynod 4 times with increases each time.
2016 Challenger SRT
The dyno indicated 11.3% going by the advertised 470. If the loss is actually like 13-15% then this engine's putting out 479-490 at the flywheel. As you said, the numbers should get better after being broken in.:thumbsup:
Video added to first post.
Tear :icon_cry:. So Awesome!
[correction]
6.1L Stock - 364 rwhp / 351 rwtq
6.4L Stock - 417 rwhp / 417 rwtq
A 53 rwhp / 66 rwtq peak improvement.
Great video and congrats on your new 392 IE, finalllllly!
6.1s only make 334 rwtq ??:scratchhead: I thought they were more like 360ish ?
Yup, sorry, a typo. I took PWR_Brads stock run so 364 rwhp / 351 rwtq is a little bit better.
Discussion Starter #13
[correction]
Thanks. I need the weather to cooperate so I can put some miles on this thing.
[correction]
Rayzazoo, are these numbers from the same dyno? If so, Dodge is pretty dead-on on the "real" power differences.
1 - 20 of 44 Posts
