Definitely use the part number above...I had gotten mine from here:
82212379 EXHAUST
If you do order yours from the dealership, ask for part number 82212379. This part number is for a SET of tips, not just one. You should not be paying more than $200 for the set.
Bump for an answer /\Is the install easy.. something a novice can do?
Can you give a quick run-down of what the install entails?yep very easy to install and adjust.:thumbsup: I know I have them on my SRT8, And if I can do it...anybody can.
1) Loosen bolt that holds circular clamp tightCan you give a quick run-down of what the install entails?
LOL, I think it took runner2go longer to type the directions than it will to replace the tips.1) Loosen bolt that holds circular clamp tight
2) Remove old exhaust tip
3) Take new Tip out of box
4) Place new tip on end of resonator where old tip was.
5) Slide clamp back into position.
6) Tighten clamp enough to hold it in place.
7) Straight tip
8) Finish tightening clamp
9) slide over to other exhaust pipe and repeat.
10) Go get a beer and admire handiwork :thumbsup:
LOL! yeah thanks runner2go, I appreciate it. I just wanted to make sure a noob like myself could do the install before I went ahead and purchased them. I think I am even capable of pulling this off. Thanks again! :browsmiley: I have never worked on cars before so I am learning everything from scratch.LOL, I think it took runner2go longer to type the directions than it will to replace the tips.Very simple, even a caveman can do it.:jester: If you are anal, like me, it will take you longer to sight align the tips (see #7) to get them "perfect".:bigthumb:
Post some before/after pics for us!Ordered mine today. Thanks for the part number.
No worries :thumbsup:any problems putting these on an RT since theyre made for an SRT with a larger exhaust
i noticed some of you guys have RTs and since no one mentioned any issues im guessing they fit on an RT no problem?
