Got these for $60.00 and figure I grind or paint over the 392 and put a 345 emblem over it. Seems some cutting has to be done but to my surprise the driver side fit perfect over the drivers side, just need to cut and grind down the front tab post that sticks out. However the other side is a problem as the transmission check tube is in the way big time. I ended up drilling a 2" hole into it then in front and back took off about a 1/4" of material, fits right over down. Have never seen this before on other mods of this type. Thought I post a picture to give others a ideal where to cut the hole. I put on a oil catch can up front and hoses seem to run pretty good under it.
Discussion Starter #2
Couple more pics.
Should of went to Steve White and got the 345 ones same problems but would have 345 on it
