Tried doing some research, having trouble finding part numbers for these suckers . Plenty of you recommend going with new bolts and gaskets for the headers if you do a swap to the 392 headers on my 5.7. Anyone have these part numbers available?
Thanks!
Discussion Starter #2
Anyone?
I found the part number for reference it is #6503131
Would i need to replace the studs as well or just the bolts? Please advise any help is appreciated!
Anyone?
Studs? Header swap , you just need the bolts and gaskets. I used oem parts for mine.
Anyone?
Ok! Sorry but i want to just be extra clear here. Theres 4 bolts on each header. Theres also some additional holes for a stud that goes into the block and stick a stud through the manifolt and is attatched with locking nuts.
You just replaced the long bolts and not the studs or locking nuts?
Headers have four on top and four on bottom to the head.
