1 - 16 of 16 Posts
‘13 Challenger SRT 6M
How come the tach in my 392 starts the "redline" at 6200 rpm but in all the specs I read about this motor it says it has a 6400 rpm redline? Which is it?
Sent from AutoGuide.com App
http://www.dragtimes
6600 when you tune it... stock is 6400.
2014 SRT Core
I've only just got past the 500 mile break in, but when I got on it the other day it seemed to be shifting at 6,000 when I had it in drive. I put it in sport mode and shifted myself and I think I got 6,200 out of it. I kind of expected it to hold gear until 6,200 when in drive.
It may with more miles / adaptives in it. 1st to 2nd shifts a little earlier than 2nd to 3rd Mine shifts in sport mode "D" at 6400 but that is with the shift points raised and rev limiter set to 6600.
rev limiter is the same as far as I know. 6400 RPM unless raised with a tuner/tune.
I understand all of this. But my question is why does the gauge show one limit and the performance data shows another? It's not a big deal, it's just an inconsistency I don't understand and wish too.
perhaps the slight delay from motor to display. I would assume the tach is behind the motor by a number of hundredths of a sec ( exactly how many I don't know) You press the gas the motor reacts, the tach then reacts to the motor. If the tach reads 6000 the motor is probably a little higher as your still on the gas. Maybe the do it to keep you from going over accidently. This is just a guess, I know about as much as you, just trying to put some logic into it..lol.
Reactions: rghoskins and SR7T1
Maybe the 6200 is where the autos shift stock... I've never logged a stock tune run to see where it shifts but it probably is a couple hundred less than red line which would be 6200.
Reactions: teddyp
Whenever I am racing I always keep the pedal to the floor and make sure I see the tach hit 6k, then I shift as fast as I can knowing I'm close to the redline/cutoff(because I do agree that the analog gauge has to lag the actual number slightly) but I have never hit it or noticed a fuel cut off.
Discussion Starter #14
Possible... Not just Edmonds though. I know sometimes the fuel cut off and rpm limiter get posted depending on the source... I have a 200rpm gap between limiter and fuel cut. That's why I asked.
Edit. Like this...
http://www.edmunds.com/jeep/grand-cherokee/2012/road-test-specs1.html
Fuel cutoff listed as 6400, rev limiter 6200.
I checked out that link. Interesting I never saw something like that. Why do you think they do that? Just wondering.
Hopefully someone with more knowledge can chime in. I just know my car had a 6000rom limiter and 6200 fuel cut stock (I noticed the rev limiter was listed as 6k in most places and 6200 in others)... When I raised it the new numbers were 6600 rev and 6800 fuel cut. Has something to do with over rev and should be kept a few hundred rpm apart but exactly how it comes together I don't know.
I did some reading on the HP Tuners software and I think I have it sort of figured out.
Rev limiter = Fuel Cutoff
This is to prevent engine damage, newer vehicles can also close the throttle plate.
Shift points / listed as rev limiter (observed per edmunds) accounts for the delay in shifting to prevent the engine from reaching the fuel cutoff.
I'll keep reading in case I screwed that up but that's what I've gathered so far.
1 - 16 of 16 Posts
