1 - 10 of 10 Posts
I added a oil catch can. I did read it is not as needed for a 3.6L as for bigger engines but always better than no catch can as i understand
Because i do not want to drill holes (make irreversible changes) and could not find the good place under the hood i decided to draw a 3D printable mount.
For now i am happy with it, did connect the hoses today and time will tell if this design holds up. It is quit firm so i think it will.
Time to share the design, so others can make use of it.
Catch can is a AliExpress buy.
1010290
1010291
1010292
1010293
Plum 2019 SXT AWD
Next oil change, open that catch can. You will see it is just as needed for the 3.6.
Also, oddly enough, I was planning to move mine exactly there and have been toying around about making a bracket, and well, here one already is.
Nice, hope you enjoy it! i might do some little changes to keep it easy printable and make it a bit more stable.
2020 Octane Red SXT
So how's it working out? Any warpage on the mount from engine heat.
Discussion Starter · #5 ·
no problems at all. best test should come this summer with full sun exposure while driving....
2020 Octane Red SXT
Yeah, I made a custom phone mount and thought I overdesigned it but nope, warped on a slightly hot day, and it's useless now. Summer will tell.
2020 Octane Red SXT
I think I did. I didn't think it would get hot enough to be a problem. And again I see now what I did wrong. Worked perfectly for a few days.
1020698
Discussion Starter · #9 ·
i print a lot of car parts most of them in PETG, that holds up good. ABS might be a good choice to, that is not always as easy printable as PETG
2020 Octane Red SXT
I mostly print PETG and PLA but this will most likely be ABS. Ill just have to move the printer to the garage and keep those fumes out of the house.
1 - 10 of 10 Posts
