I"m actually installing these next week US Gear 4.29 (03-487429LC/LX). If you want to see what your actual RPMs are going to be go to Tremec's and go to aftermarket then Support Center then Gear Ratio Calculator. it's actually spot on. I verified with my current configuration. The gear ratios for the Manual are below. I assume you have the six speed. The 4.29 gears are way too short for the 5 speed auto. You will need Richmond half install kit ( 83-1086-C ) and if you don't take the car to the dealership to have it done or a shop that has never performed this on these cars you will need special tools to help them with the install. You can find these by searching for Miller Tools then the tool number. I have them listed below. They are required to set the pinion depth and the backlash. I recommend finding Kit 10145 then grab the Pinion Block and Scooter block. You will also need the service manual to get the specs and know how to set the Pinion depth and backlash. If you have a good Chrysler/Doge dealership It may be easier to simply use them. I went this route as the dealerships near me either wouldn't install the after market parts or charge $110 an hour estimating a 6 hour job. Also please note you will notice the kit 83-1086-C doesn't have a crush sleeve.. The pinion depth is set using spacers hence the special tools.
Tools:
10148 - Installer, Pinion Head Bearing Cup
Originally Shipped In Kit Number(s) 10145.
10149-2 - Arbor
10149-5 - Washer
6739 - Block, Height
10149-1 - Block, Pinion
D-115-2A - Block, Scooter
Tremec TR-6060 Gear Ratios:
1st 2.97
2nd 2.10
3rd 1.46
4th 1.00
5th 0.74
6th 0.50
Reverse 2.90
