1 - 20 of 22 Posts
Please click on the link if you are interested in a set. Will will contact you for payment info once we have the items in stock.
By signing up you are not obligated to make the purchase but please do not sign up if you are not truly interested in this package.
Please select the kit you want and proceed to the check out screen. Again No Payment info is needed at this time just choose check by mail as payment option so we have a record of your contact info.
Thank you
http://www.modernmuscleperformance.c...e_p/64fprp.htm
http://www.modernmuscleperformance.c...e_p/57fprp.htm
6.1 drop in rods
Hey guys don't forget us 6.1 motors ! How about a 2618 piston & forged rod drop in combo . That would be the ticket.
Can you pm me price as it doesn't show up in the link for the 6.4.
Thanks,
Dale
Prices are not finalized yet but piston will be close to what it is now (2618 forging price is a bit more) and the rods should be typical pricing for a quality rod. Sorry I can not be more specific but we will do our best to keep this very affordable.
Any updates on this yet? Still no info on the website as far as price or availability.
Also need to know if the pistons will have spiro locks or be pressed on.
Thanks,
Dale
Sent from AutoGuide.com App
6.4L Pistons should be done end of February if everything checks out, and 5.7 to follow Middle of March
6.4 Pistons will keep the Floating pins and the 5.7 will also have a floating pin but sold as a piston and rod combo only
6.4 Pistons will keep the Floating pins and the 5.7 will keep the pressed pins
Chris was mistaken about the 5.7
The 5.7 will only be offered as a piston and rod combination. This for several reasons:
At the new power levels you need a floated pin
What a nightmare having shops press pistons on and off
5.7 rod and bolt combo would be a critical weak link
6.1 drop in rods
Dave are you still doing the drop in 6.1 piston & rod combo ? If so do you have any info on that , ETA ect ? Thank you again .
These are not final numbers but are pretty close (ball park).
Pistons went up a bit for the 2618 material and the reverse dome (profiled dish to match chamber)
I thought I would put them out there for all.
5.7 customers:
I know the next question will be about the 5.7 but I do not have numbers back on them yet. They should be close to the same or a bit less because we are trying to modify a shelf rod and keep cost down.
6.1 customers:
Should also have word on 6.1 drop in soon. Also same situation as 5.7 trying to use a shelf rod with mods.
Thanks David!
I will need a set of the drop I. 2618 pistons and h-beam 4340 forged drop in kits when they are available.
Also can you pm me a price for the required gaskets and a set of lifters for the same?
Thanks,
Dale
1 - 20 of 22 Posts
