1 - 1 of 1 Posts
This Father's Day, give him the gift of lighting up his other child...his Challenger!
Our illuminated LED wheel rings are an easy and effective way to light up the wheels on your car or truck! This head-turning lighting product consists of a set of (4) LED illuminated aluminum rings which install around the brake rotor and attaches to the brake dust shield. These can also be mounted to older vehicles with drum brakes. The effect is a large ring of light which accents custom wheels and stands out at events. Oversized 16.5” diameter is the largest on the market and fits oversized brakes. Our Double LED Wheel Rings are equipped with 162 super-bright 2835 LEDs (648 LEDs total) which will outshine any competitors. Choose from single-color and ColorShift for full-color control!
The ORACLE Lighting Surface Mount Afterburner LED taillight halo (with the outer section kit and the center section kit) are designed to give an aesthetic "pop" to the back of your vehicle with easy installation with no baking or cutting tail lights required! Featuring polycarbonate lenses that are resin injected resulting in an IP67 rating, these new SMD Halos are installed directly to the outside of the vehicle’s tail light lens making installation easy even for a novice!
Our concept SMD side marker lights are complete side marker replacements fitted with high powered 2835 Bridgelux LEDs that produce a laser-like appearance. We offer sets for the 2008-2014 models and for 2015-2018 models! Installation is easy! Just pop out the factory side markers and connect the new ORACLE Concept Sidemarkers right into the stock wiring connector.
Our surface mount halo kit features ORACLE SMD Halos that are resin injected resulting in an IP67 waterproof rating. These new SMD Halos are installed directly to the outside of the vehicle’s headlight lens making installation easy even for a novice! The halo kit is 12V powered and can be wired to a controller, switch, or parking light wiring harness. Choose from various single-color options or ColorShift for complete color control! We offer kits for 2008-2014 models and for 2015-2019 models.
Light up your vehicle's underbody with this specially designed kit from ORACLE Lighting! Flex LED strips feature high-quality, USA-made Bridgelux SMD chips for maximum quality, brightness, and longevity. Not only are the SMDs excellent quality, but there are more LEDs per section than our competition. Each section of LED strip comes cut to length, soldered, and heat shrunk by our own technicians here in-house. ColorShift gives you great control over colors, brightness, and patterns!
Can't decide? Browse all ORACLE Challenger products by year or pick up a digital gift card!
1 - 1 of 1 Posts
