5 speed manual transmission on my 2012 srt8 I bought.
3184 26
so I bought a challenger srt8 and I noticed that this is a 5 speed manual. I tried checking if maybe it was just damaged but I don’t think it is.
995768
Also the the reverse gear is in the top right corner
My main concern here is that the 5 speed manual will cause issues down the line and I am thinking of just buying a 6 speed and reinstalling it so I can also throw on Barton shifter. Any ideas on what the heck is going on here ?
1 - 20 of 27 Posts
2009SRT8 + 2010SRT8>69Charger
Are you sure its not just a 6 speed you are not driving correctly? Revere on a 6 speed is in the same spot as 5th, you may be trying to shift from 4th to 6th skipping 5th altogether.
Did you not just say you "so I just bought a challenger srt8"?
based on the photos that is indeed the correct Tremec 6 speed, so it is either broken, or you are not shifting it correctly
As a reference of the start of this "conversation"
I really have trouble imagining a 5-speed manual with fourth and fifth next to each other. Especially with no pattern on the shift knob, the first time attempting to shift from fourth to where fifth should be it would become evident something was wrong, evident being an understatement. I am having a hard time fathoming this issue
So this is how my transmission is View attachment 995785
No transmission that I have ever seen has that shift pattern. I'm assuming you have a 6-speed with a mechanical issue. Dodge has never built a 5-speed manual in this generation and if they did, it definitely would not have that shift pattern.
2021 JEEP Wrangler Unlimited Willys 4X4
I second that, @Slidd
I‘ve owned several front wheel drive cars and several HD diesel trucks......and none has ever had gear selection as pictured in post #7
2015 Challenger SRT 392
Wild thought. Could this be a right hand drive challenger? I don't know what the gear shifter on a right hand drive car would look like. Not sure where OP is from but wanted to throw that idea out.
Sent from my Pixel 3 XL using Tapatalk
I actually thought of that, but they use the same transmissions. Besides, it still wouldn't make sense going from 4th back to 5th back as well. I'm smelling something the Rock isn't cooking...
Shift patterns don’t change on RHD vehicles....just the arm used to select gears.
Its 100% a 6 speed (The picture he posted confirmed that), I am certain he is just skipping 5th and going from 4th to 6th. as I said, he should drive it, and try shifting into 5th while at speed
Discussion Starter · #17 ·
i will try that today and see if I have any luck but like I mentioned the car seems fine when driving. Am I able to post vids here ?
I'd look at the reverse lockout solenoid, sounds like it's not coming back to the 5th gear position.
Reactions: theblaisez24
1 - 20 of 27 Posts
