2019 F8 Green 1320
I've been looking around at different catch cans, after using Speedlogix in the past, and decided to see what was inside this cheap catch can.
The internals are different than usual, the baffle is a compressed mesh with a small mesh screen. The can itself is the same size as I've used before but the finished seems to be anodized, because it's pretty uniform, including the fittings. There are imperfections in the finish but most can't be seen and it's what I expected for this price - nothing black touchup can't fix. There's a plug on the bottom that can probably be used to put a drain. Hoses are included but not pictured and are some sort of soft braid.
It's a different can than I'm used to but it's seems of pretty decent quality.
Thoughts?
Wood Gadget Gas Automotive tire Audio equipment
Wheel Tire Automotive tire Automotive lighting Sports equipment
Tableware Wood Dishware Ingredient Flooring
Automotive tire Alloy wheel Automotive lighting Rim Audio equipment
Cosmetics Wood Tableware Drinkware Cup
The engine-specific mount is the main thing you want to make sure works when going with a no-name CC like that. As long as it bolts up properly and holds the can securely, the $50 CC is worth it in my book.
Reactions: 1320_Tony
