I'd like to know the specific engine specs for the 6.1, such as cam specs, rocker arm ratio, whatever is available. 2010 SRT Challenger.
Also at some point I will put the car on a lift. What are the best rear attaching points? I see the front frame rails, but I'm kinda wondering about the rear and where to raise it from? Thanks for the help.
i can't tell you the specs, but i used the jack area in the rear for lift points. where the little square pockets are.
Great, that helps. I saw the pockets and I think the manual shows them but was wondering if other choices were available. My friend has a 2 post lift like yours so that's perfect.I'm thinking ahead to the exhaust and pulling the wheels etc. Thank you.
