Hey guys,
I've looked all over the forum for this topic so please forgive me if I'm asking a question that has already been hashed. I'd like to conver my 2009 SRT to a 6.4L. As I understand it both use the same block and I found a piton/ring kit online for $5k. What else do I need to consider before jumping into these unfamiliar waters?
Thanks!!
Hey guys,
Thanks!!
You can just bore and stroke the 6.1L to a 392. Arrington Performance has a conversion kit. I would say, if you are going the 6.4L route, you might as well go with a 426.
Discussion Starter · #5 ·
Thanks guys...as you can see, I don't know much in this area (and don't pretend to). I looked at 426 stroker kit noted above and found it was the kit I was referring to in my first post (I didn't notice it was a 426 stroker kit...thought it was a 6.4 upgrade). What else should I consider doing while having the cylinders bored; is there anything else I should consider doing while I have the engine torn apart?
What about the computer? Does it require some type of re-program to deal with the larger engine displacement?
Thanks!
Aluminum Block 426 !!!!
Get the new Mopar 426 Aluminum block and build the hell out of if with ported heads, better valve springs and a bigger cam ;)
I had the Arrington 392 conversion installed. They also installed billet main caps, forged crank, and roller rockers. They said if i went to the 426 i would have to change to high flow cats. I live in Northern VA. Emission inspection would not pass with High flow cats. 392 with Magnuson SC and 12 lb boost gives me 603 rwhp and 700 ft lbs torque. I also upgraded the auto trans, torque converter, and axles.
P.S. my upgrade list has not been updated
