1 - 14 of 14 Posts
Calling everyone with a 6.4 cam in a 5.7. So I recently have been in communication with a tuner that says that he recommends staying with a stock cam over the 6.4 cam. Stating that it looses so much power down low it doesn’t make up for it in the power gained up higher.
Everything I have read and the dyno sheets that I have looked at seem to say otherwise.... but I’m not a tuner who has experience also.
I just want to know if I’m trying to be sold on a cam that they sell, so I want it all the good the bad the ugly.
Setup is 6.4 intake manifold, 6.4 mids/headers, 3.7 rear end.
Was planning to do the non mds 6.4 cam (Mopar apringswith hellcat lifters.
Thanks for your time
I have a very similar setup and have the cam sitting waiting for install myself
My advice? Find a dyno tuner or street tuner. Tuning over email may be efficient however when it comes to cams there is a lot to be looked over and can be tedious. It is true you may lose a little power down low, but from my research people have gained about 50-60 wheel horse. Same cam in the 6.4 makes almost 500 crank horse, and keeps your vvt working ....
Oh and did i mention its not a $1,000 custom grind?
Im taking my chances
Dont forget to get pushrods
Also it will keep you smog legal
You will loose a little bottom end but will pick up 30 hp ish up top. Don’t believe the 60 hp gains. My car picked up 2 tenths and 3 mph in the quarter.
‘15 R/T 6M STP
Pretty sure one of the moderators (Hal H?) made a comment some time ago that he did this and it made everything better. No loss down low and a decent bump up top. “Didn’t have to downshift to pass anymore“ is how I remember him describing it.
Maybe talk to some other tuners? Perhaps they have different experiences?
I swapped out heads, added shorty headers and high flow cats. So I don’t not have before and after numbers for you on the cam alone. But I can tell you that the torque curve smoothed out, and it pulls all the way to 6,000 rpm. It’s a different feel for sure than the stock cam.
Just FYI I’ve read tons of threads on the power gains I’m just trying to find the guys “who lost power”. Time to find another tuner it seems.
read the above link - for the OP > find another tuner.
That guy is talking out his (other body part than mouth)...
The only people I've seen dissatisfied with the 392 cam used a phase limiter. It doesn't need one and almost negates the power gains.
What’s surprising is that he’s a well known tuner, seems like he was trying to sell me a cam. It’s a color..... if you catch my hint at who it is.
Hell Cat lifters are the same lifters used in the 5.7, and 6.4.
Got those already based off your post!
Well yea, he sells his own cams. He wants to sell one of his own and tune it as well. Technically he’s not wrong that his would work better in terms of power, but it’s also much more expensive.
How much total was the quote for a custom cam, lifters instal and tune??
Discussion Starter #13
It wasn’t like that, I have everything I need for the 392 cam install. So I was asking about a tune started talking to me about it saying how I should leave the stock cam and how I’ll loose power. I’m about $900 for everything took advantage of the Black Friday deals, I’m talking gaskets, cam, non mds lifters and so on.
Lose power with a 6.4 cam swap in a 5.7? Nope, you will gain power...if you don't use a phase locker/limiter. It won't lope like other aggressive aftermarket cam grinds but it is easy to tune and does not require a different torque converter.
If you want proof that you will not lose power just look at the dyno chart below.
986258
1 - 14 of 14 Posts
