1 - 10 of 10 Posts
Hey all;
I seemed to have lost the screw for my 6.4 intake manifold map sensor. I work for a dealer, and there isn't a part number for that screw. Would anyone know the specs of it by chance??
Discussion Starter · #4 ·
Discussion Starter · #5 ·
turns out this isnt the screw I needed! I think it may be fine thread..WIll keep searching...if anyone has a 6.4 intake, can you get a pic of this screw?
Weird because that is the screw I used for the MAP sensor on my 392 manifold. The intake isn’t fine threaded since everything screws right into the plastic.
do you have a picture of the screw?
i purchased both the viper one and the one A Guy posted and they had identical threads, just different colors.
Discussion Starter · #7 ·
on mine at least, it seems to thread into a copper block. I can thread the first few threads, but it gets super tight
Vehicle Hood Automotive tire Trunk Automotive design
Grey Font Electronic device Monochrome photography Audio equipment
Did you buy it used? Maybe the threads were stripped and previous owner added a threaded insert. There is only 1 392 manifold part number, I bought mine new and the bolt goes straight into plastic, no insert. If it has an insert just go to a hardware store and buy a few different size bolts, one will fit.
Discussion Starter · #9 ·
I purchased it used yes. I ended up being able to get the screw in though! Helps having the proper tool lol..Thanks again!
1 - 10 of 10 Posts
