1 - 20 of 25 Posts
What would be the expected quarter mile time for a a5 392 with cai,long tubes, 85mm throttle body along with custom tune and dr's
Alot goes into determining that final E/T... weather, DA. But generally speaking:
cai, long tunes, throttle body and DRs would probably yield you 12 flat but with an auto I would probably guess 11.90 somewhere in there. With 6psi from a blower I would suspect mid low 11s
Depending on DA, tires and weight I will say 12.3 maybe 12.1
Todd
Nice
Thanks for the responses
I gotta believe 11.5 corrected
http://www.dragtimes
There is a M6 at the track I go to running 11.9s with almost 8 PSI boost in 1K DA. A5 probably mid 11s with good DRs.
mid 11's easy........I ran 11.8 @ 121 with my 2007 SRT8 Charger 6.1L. It only had catless mids, JBA catback, custom tune and 6 pound procharger. And to top it off, that was on a non drag radial street tire. Yokahama junk tire.......
In My SRT Magnum Vortec @ 7lbs I ran a 12.4 with a 2.40 60foot on street tires, With good Traction the 392 S/C will be well in the 11s
In the heat I am running 12.0's already. I am looking at Procharger and will be disappointed if it is not south of 11.5 and in great weather even better
I have the 2009 SRT and ran 13.1 stock. Bought tuner and ran 12.8. Bought HHP stage 2 pkg. ran 11.8. Installed Procharger ran 10.8. What's next? About 12 grand to get to high 9's.
Discussion Starter #13
If I ran 10 lbs of boost with forged drop in pistons is there anything else at risk for breaking and if so what should also be upgraded
Check the RWHP rating on your transmission and axle. The 2010 manual transmission is only rated for 600, so that is the weak spot after the pistons for me. Not sure what it is on your model, but the manufacturer's website has all of that.
HHP upgrade the valve body for the increase in HP. Still stock bottom end and 5 yrs old. It's all in the tuner! Josh is the man.
Discussion Starter #17
How much more horsepower can the valve body allow it to handle over stock
What was the cost
It's rated at 650 hp. Call HHP for the cost.
Discussion Starter #19
Cool thanks
1 - 20 of 25 Posts
