1 - 14 of 14 Posts
Does anyone know what you will need to reach that kind of power with an RT? Which supercharger? What internals to forge? Do you need a cam? I would like to know what other parts of the drivetrain you will need to upgrade to handle this power. What for an automatic, and for a manual? I know you will need halfshafts for a manual but what else? Also what kind of suspension is recommended? Or will the 8 speed automatic be worth waiting for?
I was always under the assumption that you can reinforce the 5.7 and turn up the boost to get to desired HP. I am wrong lol
to completely forged a 5.7 or Stroke it would be almost the same costs, Also you would need to be running 14-16 Lbs of boost to get that kind of power on the 5.7 then you IATs would be through the roof. IMO better to stroke it run 10LBS of boost and call it a day.
If I wanted to get more HP in my RT would you suggest starting with getting a supercharger or changing the heads?
I would do the blower. The heads flow very well for what they are.
Just my 2 cents but 700 hp on the street is worthless
All u will do is spin tire. I am at 550 rear wheel and that is all I do lol
thanks, my RT is an automatic by the way, will that make any difference?
You'll be faster in a straight line. Upgrade the valve body too. That will increase the pressure in the trans and push the gears together harder so it will extend the life of the trans.
I don't understand the question.
1 - 14 of 14 Posts
