1 - 3 of 3 Posts
I ordered the replacement due to the ghost touches on the radio getting realy bad
Installed the new one and I'm now missing rear camera and heated seats and steering wheel.
Is there a setting to get these back on
· Super Moderator
Welcome to Challengertalk ;) You replaced only the screen? You had battery disconnected when you changed it? Did you get a blue background when you turned it on? If so, disconnecting the battery may have caused that. A few starts and stops of the car should return to normal if so. Just changing the screen shouldn't affect the functionality
Did the Replacement screen help with the phantom touching? I swapped mine out Sunday and today it started again. The heated seats and back up camera work fine on mine. If disconnecting the battery doesn't help check the connections on the back of the radio.
1 - 3 of 3 Posts
