Since new my 2017 with navigation will let you program in favorites, saves them, then upon vehicle restart they are gone. Have had others try as well. Anyone else have this issue. Likely head unit problem, or some sort of software reprogram voodoo required?
You might try a reset:
Press and hold in the top right corner of the screen for 10 seconds, then release> The system will restart about 5 seconds after that
If no fix, check to see if Uconnect site shows any updates
If SW is latest, and still no fix, you may have to see the dealer
This sounds like a head unit issue.
As a side note, I have never disconnected my battery, but I would hope all my recent addresses are saved somewhere.
That's a good question. Many people have disconnected their batteries and can likely confirm. I would expect favorites, recent addresses, etc. are all stored in non-volatile memory, which would survive a power cycle/loss. But I can't confirm that 100%. They obviously store your Uconnect info, and I believe radio and SXM presets remain after the battery is disconnected?
That better be the case! :geek:
