I finally found a way to get an email tune from AJ at Arrington! I have a ZEX nitrous kit on order right now, and decided to upgrade to a 90mm TB from HemiShop.com that has the nitrous injection built into it instead of using the nitrous injector. http://www.shophemi.com/p-1191-hemi-90mm-cast-throttle-body-with-nitrous-injection.aspx
They told me today, if I order the 90mm TB from them, they'l have AJ send me an email tune to run it safely. I don't know if the tune will come with the TB cost-wise, but it should at least be better than running a canned tune off the Predator once I get my ARHs installed...
It is my understanding that the intake manifold is only bored to about 85mm? To maximize the flow from the new TB, I'll have to enlarge it to 90mm or larger to avoid the new airflow hitting a lip. Does anyone think it'd be wrong to fill the intake with rags/towels and do this with the intake on, then vacuum it out? Or does it need to come off to do it right? Suggestions?
Thanks guys..
Thanks guys..
