1 - 4 of 4 Posts
Will the A-8 transmission drop into the pre-2015 A-5 transmission cars?
Thinking about putting the auto-8 into my 2010 RT.
Thanks in advance,
Matt
2014 100th Annivesary R/T
Nothing but a sawzall and money cant fix!
The trans tunnel is different between the two, as well as the TCM and wiring thats where the money comes in. Best stick with the A5 in the long run.
My two cents, good luck if you move forward with it.
-Kenny
2010 Challenger R/T Classic
I’ve thought about it too, but I think the Nag1 would be cheaper and easier in the long run. Even if you did lots of mods to the Nag1.
The A8 is slightly larger but will fit without trans tunnel mods. Getting it to work is of course a different matter.
1 - 4 of 4 Posts
