My A/C was very erratic so I checked the freon and it was in normal pressures range, I did notice if I put it to recirculate the lite was yellow but I didn't hear anything (Including a rush of more air volume , so I pulled the glove box and noticed the door didn't move . turns out the pivot point broke of, and the door is not available separately.
FYI it is possible to remove it without takeing out the whole dash but take your time and go easy on it. The top and bottom halves can pullapart enough and ther is a middle 'baffle' part that looks to be molded to the top section but its not, when you pull them aprt (only about a inch) you can slid out the door.
Hope this helps someone
