There is another thread that talks about the 8 speed. Who has changed the fluid or had it changed? Youtube videos describe an involved process that includes starting the car mid process. This looks ripe for a mishap. What was your experience.
Land vehicle Vehicle Car Steering wheel Executive car
2020 Challenger R/T Scat Pak
For some reason I can't seem to find any Youtube (or other) video's that specifically describe an ATF change in a ZF8HP70 or ZF8HP90 in a Challenger/Charger. I can find them for other vehicle brands but not Dodge.
DeWFPo
2016 Jazz Blue A8 Scat
The filter is inside the pan and doesn't come out. You buy a whole new pan and filter assembly. There is a drain plug made into the pan. The fill port is on the side of the case.
To check the level requires the trans fluid to be at a certain temperature and you check it just like a rear diff where the fluid needs to be level with the plug.
The only hard part is filling it since you have to pump the fluid into it.
Reactions: Dennis H
Discussion Starter · #5 ·
