1 - 2 of 2 Posts
my AC takes forever to turn on and sometimes won’t even turn on, has anybody else ever had this issue? The heat turns on right away, but the AC doesn’t, on the coldest setting with the fan on high.
Are there any other indications of off-nominal operation, like blinking lights on the HVAC control knobs or erratic RPM when A/C engaged?
Does the A/C light on the HVAC knob immediately light up when you engage the A/C?
Can you hear the compressor kick on and off when the A/C is on?
Does putting it in recirculate (max a/c) have any effect on this behavior?
What is the ambient air temperature, approximate relative humidity, and air temperature coming out of the vents when the A/C does finally come on?
1 - 2 of 2 Posts
