This is a compilation of commonly used acronyms here at Challengertalk contributed by the members. If you are new to the forum, or just wonder what the heck MDS is, or SPAG, you will hopefully find it here. This isn't meant to be a list of common acronyms on the internet, but rather acronyms that are more specific to Challengertalk. Feel free to suggest any that we have missed so far, and I will add them if they fit the criteria. Thanks to everyone who has contributed to the list
5.0 = Uconnect 5" Head Unit
7.0= Uconnect 7" Head Unit
8.4 = Uconnect 8.4" Head Unit
A5 = 5 speed automatic
A8 = 8 speed automatic
ABS = Antilock Brake System
AEV = Active Exhaust Valves
AFR = Air Fuel Ratio
AT = Automatic Transmission
ATF = Automatic Transmission Fluid
AWD = All Wheel Drive
Axle Back = Exhaust system after the rear axle
B5 = B5 Blue Color
BCM = Body Control Module
Blower = Supercharger (See also SC)
BOV = Blow Off Valve
Brembo 4 = 4 Piston Brembo Brakes
Brembo 6 = 6 Piston Brembo Brakes
CAI= Cold Air Intake
Cats = Catalytic Converters
Cat Back = Exhaust system after the Catalytic Converter
Catted Mids = Midpipes with Catalytic Converters built in
CDV = Clutch Delay Valve
CEL = Check Engine Light
COP = Coil On Plug
DCG = Drivers Convenience Group Package
DD = Daily Driver
DI = Direct Injection/Direct Fuel Injection
DR= Drag Radials
DRLs = Daytime Running Lights
DS = Drive Shaft
DTC = Diagnostic Trouble Code
ECT = Engine Coolant Temp
EGR = Exhaust Gas Recirculation
EGT = Exhaust Gas Temperature
EHPS = Electro-Hydraulic Power Steering
ESC = Electronic Stability Control
EVIC = Electronic Vehicle Information Center
F8 = F8 Green Color
FCA = Fiat Chrysler Automobiles
FI = Forced Induction or Fuel Injection
FM = Friction Modifier
Forged = Adding Forged internal engine parts to replace weaker cast parts. Most notably Forged Pistons
FSM = Factory Service Manual
FWD = Front-Wheel Drive
Gen3 or GenIII = 3rd generation Hemi Engine
Getrag = Limited Slip Differential
HC= Hellcat
HEMI = Hemispherical combustion chambers
HID = High Intensity Discharge Headlights
HF Cats = High Flow Catalytic Converters
HLA = Hydraulic Lash Adjuster
HU = Head Unit
HUD = Heads-Up Display
HVAC = Heating, Ventilation, and Air Conditioning
IAT = Intake Air Temperature
ICE = Internal Combustion Engine
IFS = Independent Front Suspension
iDFSO = Interactive Decel Fuel Shut-Off
IRS = Independent Rear Suspension
LA = 2015- Current Challenger Platform
LC = 2008-2014 Challenger Platform
LCA = Lower Control Arm
LHD = Left Hand Drive
LSA = Lobe Separation Angle (Camshaft)
LSD = Limited Slip Differential
LT = Long Tube Headers
M6 = 6 speed manual
MAP = Manifold Air Pressure (IE: MAP Sensor)
MF = Microfiber (C'mon now, get your head out of the gutter! )
Mids = Mid Mufflers or Mid Pipes
MDS = Multi Displacement System
MIL = Malfunction Indicator Light
MOPAR= Combination of the words MOtor and PARts. Parts, service and customer care organization within Fiat Chrysler Automobiles
MT = Manual Transmission
MY = Model Year
NA = Naturally Aspirated
NAG/NAG1 = 5 speed automatic transmission (New Automatic Gearbox 1 [1st Generation])
NOS = Nitrous Oxide or Nitrous Oxide System
NVH = Noise, Vibration, and Harshness
O2s = Oxygen Sensors
OCI = Oil Change Interval
PCM = Powertrain Control Module
PCP = Plum Crazy Purple/Plum Crazy Pearl color
PCV = Positive Crankcase Ventilation (IE: PCV Valve)
PDC= Power Distribution Center
PDI = Pre-Delivery Inspection
PN = Part Number
POC = Priced Order Confirmation
PP = Performance Pages
PPF = Paint Protection Film
PSI = Pounds per Square Inch
Raisin Bran Hood = New "Two Scoop" Hellcat hood
Reps = Replica Wheels (IE: Hellcat Reps, Demon Reps)
Res Delete = Resonator Delete
RHD = Right Hand Drive
RWD = Rear Wheel Drive
RWHP = Rear Wheel Horsepower
SA = Spark Advance
SC = Supercharged, or Supercharger
SG or SGII = Sound Group, Audio System
Shaker = Shaker Hood Scoop
SI/DO = Single In, Dual Out muffler design
SI/SO = Single In, Single Out muffler design
Six Pack = Three two-barrel carburetors
SP = Scat Pack
SPAG = Scat Pack Appearance Group
SPS = Scat Pack Shaker
SPWB = Scat Pack Wide Body
Squirters = Nozzles that squirt oil under the piston to keep them cooler
SRS = Supplemental Restraint System
SRT = Street & Racing Technology (High Performance Group Of FCA)
STP = Super Track Pak
ST or Shorties or Shortys = Shorty Headers
TCM = Transmission Control Module
TIPM = Totally Integrated Power Module
TB = Throttle Body
TPMS = Tire Pressure Monitoring System
TSB = Technical Service Bulletin
TW = Treadwear
UCA = Upper Control Arm
UOA = Used Oil Analysis
VIN = Vehicle Identification Number
VON = Vehicle Order Number
VVT = Variable Valve Timing
WB = Wide Body
WBSP = Wide Body Scat Pack
WBSPS = Wide Body Scat Pack Shaker
WIN Module = Wireless Ignition Node
WOT = Wide Open Throttle
ZF = Manufacturer of 8 Speed Automatic Transmission (2015+) (See also A8), and 2015+ Rear Differentials
B5 = B5 Blue Color
COP = Coil On Plug
DD = Daily Driver
DR= Drag Radials
DS = Drive Shaft
F8 = F8 Green Color
HC= Hellcat
HU = Head Unit
M6 = 6 speed manual
MY = Model Year
PN = Part Number
SA = Spark Advance
SP = Scat Pack
TB = Throttle Body
TW = Treadwear
WB = Wide Body
