I have a 2017 T/A. If I get a delete for the muffler but keep the resonator that’s before the axle will that trip any codes?
2014 Challenger SRT 8
nope
What resonator before the axle?
My understanding is that the muffler looking parts before the rear axles are resonators and the actual mufflers are behind the axles. Some have called both sets mufflers but resonators would make more sense.
No, that is backwards (at least regarding Challenger). Mufflers are forward and resonators are at the rear bumper. Always a lot of confusion and this shows why you never tell a muffler shop what you want done, you walk out in the shop and point to what you want removed, otherwise they might screw it up as they have many times according to posts I've read.
To the best of my knowledge.....resonators will always be the last component in an exhaust system.
Not always. It depends on the entire system. I’ve actually had them sitting in place of cats behind a set of long tubes in order to mellow out the sound a bit from just an off road x-pipe. Did the trick nicely.
I believe he meant OEM from the factory
2017 yellow jacket RT
I purchased a 2017 manual rt which the previous owner had the mid mufflers deleted, no check engine of any kinds. Sounds great too ?
