1 - 17 of 17 Posts
Has anyone ever upgraded their stock suspension Challenger R/T by adding the STP components? If you have would you please elaborate on exactly what parts you changed and an approximate cost to do this?
Any information is greatly appreciated.
TIA.
4 springs, 4 shocks, sway bars, different steering components, different brakes, etc
the smart thing to do is to upgrade instead of concentrating on matching, would recommend stage one springs and Bilsteins shocks and struts, acr stage 2 sway bars
springs when available 220.00
shocks 550.00
acr sway bars 450.00
by the way the rear sway bar is a bear to change
Luke
Upgrading isn't an option, mine is a '13 with less than 1500 miles on the clock so the loss I would take on a trade up puts me in a sticky situation.
But, thank you for your response, I would imagine that the brakes would be a logical place to start since they are probably the most expensive things to upgrade.
Lots to think about, but you're right and if things were different I would just trade up. 2015 is coming too so let's see what things are like then.
Luke didn't mean upgrading for another car, but for better parts than the STP factory ones. Beat the STP instead of matching it part for part.
Yep
If you are going to spend $$$, might as well get the good stuff...
Duh... Thanks for setting me straight.
Reactions: USRWDV8
Think the brakes themselves are the same, and that only the brake pads on the STP are different. Part number confirmations should be easy with your dealer parts man.
Also one thing factory STP automatic cars had was the ability to go full off on the ESP. All SRT's and 6-speed R/T's can all do this already but the only way the R/T automatic could do it was to order STP.
EDIT: Ok Duh's on me now....I see you have a 6-speed.
sorry, did not mean to trade vehicles, but upgrade components, instead of trying to match components
Luke
not necessarily on the brakes, you can have 3 different levels
BR3 - STANDARD 4 WHEEL DISC BRAKES
BR5 - PERFORMANCE BRAKES 4 WHEEL DISC BRAKES
BR6 - HD 4 WHEEL DISC BRAKES ( STP OPTION )
ALSO
BR4 - BREMBO ( FOUND ON SRT ONLY )
Discussion Starter #10 (Edited)
What is the difference between BR5 and BR6?
Luke, I see that your eBay store has complete sets of the sway bars and shocks rather than buying separate pieces. Does MoPar offer a conversion "kit" to go from BR5 to BR6 or are the parts all sold separately?
ALSO
I wonder what the difference is between the 3. Pad compound and valving,or physical difference?
/QUOTE]
My RT is a 6M and I can't go full off ESP, unless I'm doing it wrong?
Quick touch of the button turns off traction control, holding the button down in a few seconds will turn off ESP, or about 80% of it as has been posted in other threads.
Thank you sooooo much! I can't believe I was only using partial TCS and thought only "Super Track Pack" cars had full off! I tried it this morning and sure enough, it went full off! When I tried it before I was moving and that's why it wouldn't activate. Now my tires are gonna wear out even faster.
I apologize to the OP for this digression.
Out of curiosity regarding the 'variable' STP steering...does this still use the electric power steering pump as on the standard R/T, or go back to an engine driven pump?
Yeah isn't it great? I drive mine in this mode most of the time and it does run better I believe. The 6-speed cars got a lot of love from Dodge and am very glad I got one.
I think the earlier STP cars held on to the engine driven pump longer but now they are also electric (think the SRT will be electric for 2015 too). Not sure exactly when they changed, 2013? maybe, but for 2014 all electric.
Here's a build sheet of an Anniversary STP:
http://www.dodge.com/webselfservice/BuildSheetServlet?vin=2C3CDYBT9EH218744
1 - 17 of 17 Posts
