1 - 10 of 10 Posts
Read Only
I have a 2019 Challenger 1320. I installed front and rear strut towers, and it's helped out the handling quite a bit. I no longer have to stomp on the brakes going around the slightest of curves....
I was thinking of going even further, and adding the Eibach Anti-Roll Front and Rear Sway Bars.
Has anyone had this installed and what are your thoughts?
I installed the front sway bar IMO it makes a big difference very easy install
RT plus 2015 use the back hole not the front one
Hood Automotive lighting Bumper Font Automotive tail & brake light
Wheel Tire Vehicle Automotive lighting Automotive tire
Reactions: 249983
Eibach was what I considered but ultimately I installed Whiteline front and rear sways. Absolutely love them.
I did use Eibach springs to lower mine.
Handling is much better for my purposes.
Good luck.
I put the Eibach on my front for my 2015 SPS. I did this after the front and rear shock tower. I went with it as it has a larger diameter than the OE sway bar. I skipped the rear as it was the same size as what Eibach was offering as an "upgrade" plus the rear is a PITA to swap.
I'm ral happy with my set up. I will not be looking aw lowering springs.
"The rear was a PITA" you say. YEP, A bit but definitely do-able. Did mine on jack stands in the garage. Had to remove all the cradle bolts and lower it to get it swapped out. Just a little extra sweat equity ya know.
Hotchkis sways went on my 2010 and absolutely no complaints. If the rear cradle is dropped it should get realigned.
Did you remove the exhaust? Did you need a realignment after dropping the rear cradle? Just curious
I didn't remove the exhaust, just unbloted it from the body and allowed it to rest on a 4X4. I didn't do an alignment. So many differing opinions out there. When I do new wheels and tires I'll align it. Been a couple hundred miles and I'm not seeing any tread wear issues.
I'll be able to confirm that after wheels and tires.
Let us know what it did to your 60' time.
Someone buys a 1320 and then wants it to turn corners. There's only 1 turn at the end of a 1320' race
1 - 10 of 10 Posts
