AFE DRY DROP IN FILTER 2011-2016 CHALLENGER/CHARGER/300
Constructed with 100% polyurethane on all sides, "oil free" OE replacement performance filter will outflow the stock filter by up to 25% for improved horsepower and torque. The Pro DRY S air filter uses three layers of progressively finer mesh cotton gauze media to provide maximum airflow for best performance results. Washable and reusable for multiple cleaning cycles, the tall, open, evenly spaced pleats provide excellent dust holding capacity for a longer service cycle between cleanings. An integrated urethane bump seal insures tight, no leak seal over the life of the filter.
Pro DRY S Media: This filter features 3-layers of progressive media to provide maximum flow with excellent filtration. The progressive layering of media allows the filter to flow at high levels even when dirty. The Pro DRY S non-oiled synthetic air filter requires no oils for cleaning for maximum convenience.
Rounded Open Pleats: aFe performance air filters use a rounded pleat design which produces more useable filter surface area for increased flow and greater dust holding capacity.
Progressive Bump Seal: This pliable sealing surface conforms to even the most uneven filter housing. This design eliminates the use of gaskets or sealants. The soft urethane construction always goes back to its original form so you will never compress the bump seal. This makes for a perfect filter fit and sealing surface every time.
Full Urethane Housing: aFe Power performance air filters are constructed using full 360 degree urethane frames. This construction allows for a proper OE style fit with excellent filter strength.
aFe Power OE replacement performance filters have a limited lifetime warranty.
To Order: aFe Dry Drop In Filter 2011-2016 Challenger/Charger/300
Thanks
Chris
About this Discussion
1 Participant
Speedlogix-Sales
Dodge Challenger Forum
Full Forum Listing
