I just bought those same red billet pedals earlier today. How in God's green earth did you install those things. The gas pedal l bracket slides off the back and the brake pedal screws won't fit over the four corner ones evenly please help.
Yes,they are a tad small on one corner of each pedal cover.I drilled one hole through the the front of the brake pedal at the lower left corner and used a bolt and nut to fasten the cover.For the gas pedals I drilled two holes.One at the top centre and the other at the lower left.Again,I used a bolt and nut to fasten the cover to the pedal.I also used the clip fasteners that came with the pedal.See photos for further details.
I also formed the pedal covers for a better fit buy bending them until they had the same surface curve as the brake and gas pedals.It doesn't take much effort to do this.Just place the pedal cover on the edge of a work bench apply pressure by hand until you get the curve right.
I installed these covers a few years ago and they have not come loose at all.A little patience and it will all fall into place.
