I had my rt called in for the timing chain problem. I originally had a 180 jet before I went in to the dealer, but I have a feeling they replaced it with the original one. Do they replace it when they replace the timing chain?
2016 R/T Scat Pack
They shouldn't have changed it. They do the chain, guide, and tensioner, and change the oil and filter. I had mine done 2 weeks ago...
They most probably didn't change it and if they had to they would've charged you as it isn't part of the recall.
http://www.dragtimes
if you loaded your orig back up before taking it in, then your fans were set for 219 or so for the HS fan.
reloading your performance tune with adjusted fan settings will do it.
