1 - 14 of 14 Posts
Lots of stuff in my garage/house that I am looking to move. Condensing several threads I have floating around out there as well as adding some new things to the list. Let me know what you are interested in.
1. Eagle intake manifold- cleaned in and out and taped up, includes all oem intake to head bolts, oil cap, pcv valve, pcv hose and manifold to intake hose. Foam in back of intake included. NO map sensor. Perfect condition. $250 obo shipped in the 48.
2. Set of 8 MOPAR intake manifold gaskets part: 53022143ab. If you know about these, you know they are hideously expensive at $10 a piece give or take. Also a mopar throttle body gasket: 53022320ab and 2 pcv/oil intake manifold gaskets: 53032384ab. All are new and meant for 2009+ plastic manifold hemis. $90 for all of it shipped in the 48. Rather not separate but will consider.
3. MMX eagle intake to non-eagle head adapter plates. Includes orings and longer bolts/washers. $200 shipped in the 48.
4. A mopar power steering pump part: 4782524AD WITH a HHP racing aluminum pulley installed on it. Pulley is meant for serpentine belt blowers that may break the stock pulley. Pulley is 300+ and pump is 200+ new. Runs fine, 20k miles on pump, will not separate. $300 obo shipped in the 48.
5. BMR suspensions rear aluminum cradle bushings SCB112. universal to the Challenger, charger, 300 and magnum. New never installed, $200 shipped.
6. One 56029467ag tire pressure module assembly new in box from mopar. $50 shipped.
7. All new internals to a 3.91 Getrag including gears, springs, friction material and bearings. 0 miles were on it. Pulled it to put in 4.10s in a new assembly. Make me an offer on all of it.
8. All rear seatbelt components from my 13’ Challenger. All three belt assemblies and buckles, bolts as well. Like new. No snags or stains. Dark grey. Not even used since no one was ever in the back of my car before I pulled them out lol. Make me an offer.
9. Solid motor mounts for a 05-10 5.7 or 6.1 challenger charger 300 or magnum. $120 shipped
10. Oem throttle body “847” style (04591847ac). Got it secondhand with supposedly 20k on it. Put it on my 06 charger and it ran fine so I pulled it off (in preparation to have it ported. $70 shipped.
11. Set of 8 oem 6.1 or 2009+ 5.7 injectors. Bought secondhand. Not cleaned or flowed but did put them in my challenger race car (use same injectors) to verify they ran then pulled them. $70 shipped.
Have pictures of most of these readily available and will get pictures of stuff I don’t and update soon. If you need info faster, pm me. Everything is located in AZ.
I’m poor, help me move this stuff!
Thanks everyone.
Discussion Starter · #2 ·
Additional:
12. Set of 2 flowmaster clamp on tips part 15375. Never used and in original boxes. Meant for 2.25” pipes and are 3” outlet. $80 shipped.
And here is a picture of the motor mounts that were never installed:
Discussion Starter · #4 ·
Power steering pump and pulley SOLD!!!
Discussion Starter · #5 ·
Bump
Discussion Starter · #6 ·
Bump
Discussion Starter · #7 ·
Monday bump! Everything is obo!
Discussion Starter · #9 ·
Still have the Engine Mounts?? Interested! Msg me ASAP please, possibly the rear cradle bushings too.. :)
Sent
Discussion Starter · #10 ·
Motor mounts sold!
Discussion Starter · #11 ·
Monday bump!
Discussion Starter · #12 ·
Sunday bump! Come on people, I know someone needs something!
Discussion Starter · #13 ·
Cyber Monday bump? Yes sirrrr everything is OBO!!!
Discussion Starter · #14 ·
Eagle intake/head adapters sold!
1 - 14 of 14 Posts
