Aftermarket gauge placement
1131 7
So i need to add a few gauges into my car. Nitrous pressure,afr, low fuel pressure gauge. Also aftermarket shift light, cause i dam sure cant see the dot in the cluster. Ive got the '15 dash. I have the roof mount but still need one more location. I dont like the pillar mount because if the curtain bag ever goes off, pillar mount is going to go flying.
Any ideas or suggestions?
Subwoofer Audio equipment Bumper Automotive exterior Automotive lighting
Synthetic rubber Tire Concrete Automotive tire Cylinder
I posted the step file for an overhead gauge pod on thingiverse.
It can be modified to possibly add a 3 gauge.
Ive got 2& 1/16 gauges and only see 2 gauges fitting into the overhead cubby hole. Smaller gauges, maybe but already purchased the holder and gauges. Was thinking of putting the shift light where its at in the pic attached. Not in the line of sight but still should be bright enough to see it. Just need a flash from it anyways.
Wire Tire Auto part Technology Floor
Discussion Starter · #5 ·
Id have to agree with you on the the 3rd looking a little too busy/tacky. You have a 3d printer? I could remove one ac vent and block the airflow off and put the gauge instead of the vent. I havent seen one for sale or available.
Vehicle Car Ford motor company Family car
Would need contour outline of the opening for that, which would require me removing the vent, making a outline and then transfer it digital. A bunch of work for something I won't ever use. The sunglass pod literally only took about an hour to design in solidworks.
