1 - 1 of 1 Posts
We will be offering both systems for sale Basic and Pro, these are not your normal air bag system but designed for performance!
Airtech Basic Suspension System
Unlike air bag suspension systems of the past where consumers must piece together a complete kit from scratch, often at a compromise to reliability and performance, KSport’s revolutionary Airtech Suspension System comes as a complete, model specific kit that is 100% bolt-on with no custom modifications needed. Each Airtech Suspension System is fully developed for a particular vehicle with model specific dampers, air compressors, lines, wiring harnesses and instructions. KSport is proud to kiss the incomplete air bag suspension systems of the past, goodbye! All Airtech Suspension Systems include KSport’s monotube coil over dampers with air bags that are pre-installed at the factory. All dampers utilize billet, 6061 aluminum components with zinc electroplated steel shafts that are resistant to salt, rust, dirt and other harmful environmental conditions. The dampers offer 36 levels of adjustment, simultaneously altering rebound and compression. Ride height is adjusted through the air bags which can be controlled internally in the cockpit, or remotely with KSport’s award winning keyfob-style height adjustment controller. Height adjustment can also be performed on the damper itself by using KSport’s unique adjustable mounting technology, which allows height adjustment without sacrificing suspension travel or ride comfort.
Airtech Suspension System kits come complete with Viair air compressors, all necessary wiring and plumbing materials, instructions, and height adjustment controls for in-car and remote use. With the convenience of Airtech’s bolt-on installation, excellent ride comfort and versatility, KSport has changed the way enthusiasts approach and utilize high quality air bag suspension systems. With no compromise in quality, safety and performance, Airtech Suspension Systems are a must have item for anyone interested in leading-egde technology, at a competitive price.
Features
  1. 1 – 5gal air tank 9 port
  2. 1 – Viair 380c compressor, 200psi 100% duty cycle
  3. 1 – 200psi pressure switch
  4. 1 – Silencing base plate
  5. 2 – paddle valve switch
  6. 1 – 200psi dual needle gauge
  7. 1 – Bracket for gauge and switches
  8. ¼” high pressure air line
  9. Power Wire
  10. 1 – Fuse Box
  11. 4 – Full Struts with adjustable lower mount, aluminum top mounts, and 36 levels of damping adjustment
  12. 4 – High pressure airbags
Airtech Pro Suspension System
Features
  2. 2 – Viair 380c compressor, 200psi 100% duty cycle
  5. 2 – electronic switches
  9. Power Wire
  10. 1 – Fuse Box
  13. 4 – electric Solenoids
  14. 2 – ¼” Valves
  15. Wireless remote control
The list price for the Basic system is $4,300 and the Pro system is $5,200 but our prices are so low we can not even post them PM me for pricing and details. There are 7 of both in stock ready to ship.
1 - 1 of 1 Posts
