I see a lot of videos about "popping" out the back cover/plug from the air catcher lamps. I have a 19 Scat Pak and the back of my lamps look completely different. It appears to have some sort of screw out plug. Looks like it might have a set screw too. Any experience with these? Can they be removed? TIA
2019 Dodge Challenger Widebody Scat Pack
I was able to get the cap off the driver's side light. The passenger side was too difficult to get a good angle on. I forgot the size of the Torx head, but it was pretty small.
I bought a mini Milwaukee kit at Lowe’s with sockets and all kinds of torx heads, like $15-20. Was able to get both off easily In minutes with that, I can send you the model if you’re interested, let me know.
I used a torx 10 bit and a 1/4 combination wrench and a ratchet wrench when I figured out it would work quickly. I did have to remove the passenger side ABS cover to make room for my hands. This snaps off easily and is held be the same fasteners holding the battery cable.
