I recently installed an NRG hub, quick release and a grip royal wheel, I had to remove the clock spring and obviously the airbag. Now I have an airbag light and a traction control light. Does anyone know the output of the airbag wire or what specific resistor I need to turn off the lights?
For pinouts go here
for wiring diagrams and service info go here
I thought you might be able to suppress using alfaobd but there is no configuration setting for that.
1018959
Your traction/stability light is probably because your clock spring assembly is gone. The cars computer needs to know where the steering wheel is pointed (although I’m not exactly sure where it’s grabbing that information).
hopefully this is a race car because you killed some really worthwhile systems.
If I can get the clock spring back in, what do I lose not running a driver side airbag? And is there any resistor i can plug in the airbag connector to get rid of the light?(I don’t know the output of the connector)
"what do I lose not running a driver side airbag?"
Possibly your life. My Father was an Engineer for GM, spent 22 years in the Supplemental Restraint Department. He told me ANY front crash type impact over 40 MPH, could kill you, even with airbags. It's not the impact, it's the sudden deceleration. With NO airbags, you are relying on the seatbelt to save your life. You'll likely snap your neck.
Remember you only get 1 life.
