1 - 2 of 2 Posts
Not sure if this is the right place to post this.
I may be removing my CAI and putting the Hellcat airbox back in my car. I seem to recall when I removed the airbox last year, the foam-gasket-seal thingy that seals the bottom of the airbox to the bottom inlet was worn-out, so I'd like to replace it for when I put the airbox back.
So my question is: what do you guys use to replace the OEM foam-gasket-seal thingy to get a tight air seal on the bottom air inlet?
This vid shows using frostking foam weather seal with adhesive backing, sold at stores like home depot, ace , etc. thats what I used as well, been holding up perfectly.
> https://youtu.be/hYezkfpI2MU <
1 - 2 of 2 Posts
