1 - 1 of 1 Posts
Lowered on D2 coil overs. I love the height/look/stance. No rubbing. However camber is way off spec.
Need some professional/experienced help:
D2's advertise "Upper camber plates and pillow ball mounts *certain applications" shop/installers i went with say for '11 R/T D2's don't have camber plates. Can someone confirm? And what you see is the best they can do alignment wise.
If that's true should I just get some type of camber kit/adjustable UCA to correct the camber?
If not true...obviously I need to take to a different shop and hopefully the camber plates will get me closer to spec.
Installers said raising slightly would get camber closer to acceptable range. Im also getting a slight pull to the right.
Thoughts/advice?
Thanks in advance. BTW i am not mechanically savvy..thus the post for help.
1 - 1 of 1 Posts
