you said you got them for an se? which wheel and size/offset and such did you end up getting? i have a redline 3 and am looking at the regular boss's but those black ones are really sharpI do not believe the 338's will fit...I own an SE and when I ordered them from America's tire the guy had to call and ask if I had an SRT because they would not fit...not sure what the off set and everything was...hope that helps a little...
I did not pick I just ordered them...I have the front two and they are 20x8.5 bolt pattern 5 on 115mm back bore size 82.80mm and offset 14mm I will have the rears which are 20x10's tomorrow, so ill list those specs tomorrow...you said you got them for an se? which wheel and size/offset and such did you end up getting? i have a redline 3 and am looking at the regular boss's but those black ones are really sharp
