2009 SRT-8
The outer edges of both front tires on my 2009 SRT (10,400 miles) are extremely worn, is this a normal thing or do I have an alignment issue?
The tire are the factory Goodyear Eagle F1.
How fast do you take corners?
I would get the alignment checked. Often cars from the factory can become misaligned due to chassis transport straps used during shipment.
Good point. The written shipping instructions from FCA say only tire straps are to be used for securement but some truckers still using chains. :mad:
F1s are notorious for wearing quickly, especially for a lot of stop/go driving in town. Softer compound is the main reason with this "3 season / summer" type of tire.
rotate the tires every 6K (Chrysler recommends) and probably have alignment checked - it might not be at optimum spec.
I recall a number the early SRT models owners commenting on getting wear like this. The later years '11+, the camber is more aggressive and tire rotation is especially important to do...
Well, maybe a bit spirited on curvey on/off ramps...Ontario's pretty flat, w/ grid pattern streets....
Will definitely get an alignment after I get new summer rubber. Probably 275's at the rear and 255 up front on the Alcoas :roller:
2009 SRT-8
Update, I replaced the front tires and had a FE alignment done, they found and corrected a toe adjustment.
