Anyone have them installed yet ?Razor's Edge for me......definitely the most rigid due to the geometry of the brace.
Because it says mopar...and unless you want it for the name, I would recommend the razors over the mopar any day. Better design and also chro moly vs mild steel in addition to being less moneyAnyone have them installed yet ?
Why is the mopar more $$$ than the razor's edge ??
dumb question but is the one in the middle the razor? top one says lakewood, bottom says mopar. where do the additional ends bolt into?Because it says mopar...and unless you want it for the name, I would recommend the razors over the mopar any day. Better design and also chro moly vs mild steel in addition to being less money
Nice ! GWE , I'm GWE cuz I don't have a GWEI put the Mopar one on my GWE because I all ready had it from my B5 R/T.
:bigthumb:
Yes bolts right up. If you plan to do a rear inlet blower like the kb, then we have a version that is designed to clear it...I would just get that up front if yu intend to install a sc at a later date.Does it bolt up aka no modification needed to install ?
Also just curious here, are there clearence issues
if you did a roots / twin screw blower ?
I installed it at about 50 miles on the car, so can't really say what a difference it make, but on my '09 R/T I could tell a difference.:thumbsup:Nice ! GWE , I'm GWE cuz I don't have a GWE
Do you notice a significant difference in handling when you
toss that pup side to side ?
Cut down on body roll ?
